Fault: Constant Buzzer Warning Mk2 1990
Newtchaser
My Toyota Carina expert friend is away on holidays just when I needed him so having discovered you guys I'm asking here for your guidance. There is a constant buzzing sound internally. I had this once before and it was the sun roof not quite shut. It appeared to start when I opened the trunk which happened to be not in the locked position despite the car being locked overnight. I would gladly snip the feed to the buzzer if I knew where to find it?
Problem found. Not the car but a portable Battery pack/starter run low on charge...duh!
