Replacement Bulbs 2012+
vpcca
Hi, did anyone have any luck with LED bulbs for the sidelight/DRL?
i bought vanssi leds from Amazon and they only flash once.
Dont really fancy the blue halogens
  • 1 year later...
Hi all,
I've just been reading this tread, one thing that hasn't been mentioned is that most LED's are not the same as bulbs as the polarity is crucial. If a LED does not work, you might get it to work by changing the poles, which means turning the bulb 180 degrees in the bulb holder.  LED are diodes which means they allow current to flow in one direction, standard bulb will work when current is applied in any direction.
I hope this is clear, because reading it back I cant find the words to describe what I mean. All I'm trying to say is if LEDs dont work first time then try  turning them around
Paul.
