Interior Light Bulb Change E12
Rasmalai
Hi, I tried to remove the plastic cover on the interior light but it wasn't coming off and there was no indication as to where you could remove it. When attempting to pull off I noticed the whole thing including the on off and door switch was coming off. How can I remove the cover in order to change the bulb or do I need to pull the whole thing off?
Are you in the right forum , you show an Auris ?
Looking at my manual it says you have to use a small , very thin screwdriver, between the lens cover and its body, to unclip the lens cover.
Expect you will have to be careful, too much force , or too big a blade, and you will crack the parts !
Thanks. I have an auris and a Corolla.
E12 pre-facelift interior lights
Front driver/passenger light- ba9s
Middle light - festoon 269 30-31mm
Rear boot light- festoon 269 30-31mm
Bought these after read the first post to upgrade my lights
Flat head screw driver in the front and middle lights, on the covers and they pop off
