Upgrade 2009 Stereo To Double Din
anthonyk2010
it looks right to me, un plug the leads from the factory radio  and plug them in to the harness
give me a while and i will draw a diagram
I tried but trust me they look that they are going to fit the oem plug on the harness but when you try they don't...
Enviado do meu EML-L09 através do Tapatalk
its because they are low quality, the plugs are very tight, you have to line the pins up by wiggling them due to poor moulding and fitment
you get what you pay for - these stereos are made very cheaply in china if you paid $3-400 its cost them less than $25 to make
i have fitted lots of radios over the years and the no name ones off aliexpress and the like are junk and give nothing but issues including fitting them
its because they are low quality, the plugs are very tight and you have to line the pins up by wiggling them due to poor moulding and fitment
Yap I bought a universal 9" and is giving me so much. Also the harness has less pins attached that the original plugs... Do you think I can "force" them a little so the plugs fit on the harness?? 48036ab63f59a582d6ded1a7da1e1cdf.jpg
Show a photo of the rear of the stereo and the wiring harness that came with it? Bob as said it above, no name units don't come with the standard ISO harness like unit from Pioneer, JVC, Sony, Kenwood to name a few.
See bellow. 3rd photo is another cables that I've bought a part trying to solve the problem because the ones with the radio only have 2 plugs... 9b685505ec713c024377cfdf94c710be.jpg146143fe8507dcb6739f722bbb0137d2.jpg9bcb1e832abf45b56ff8dafc0663b851.jpg
Also I'm going to be able to use steering wheel controls?
It depends on the interface and brand. If the interface is generic with other brands, then you might get steering controls.
What do you mean by interface? Only have cables attached 3b0955b7358cf4e286d2e0050e623209.jpg
There are some interfaces (not the connectors) that work whatever the brand of stereo or car. Some are programmable. In UK brands like https://autoleads.co.uk/ and https://connects2.com/ that supply interfaces. There are also 'Chinese' versions if you search. It's all about using the correct words to find what you need. If I find somebody who has installed a no name Android unit successfully, I will link to this page. Also check the https://www.toyotaownersclub.com/forums/forum/19-audiovideoelectronics/
page, which may have info, since most Toyota use the same plugs and interfaces.
Thank so much for your help I will try to get this websites and investigate this more
  • 5 months later...
Hello. Finally I see the light on the end of the tunnel eheh can anyone tell me is possible on this aftermarket Chinese radios use the original oem rear back up camera? bd2ef6603ebe86eaf55bef76615dbec4.jpg106dd6846222757979e20bfbbbd32af7.jpg
