Good News?
stompe
Interesting regarding the cooling system and other changes.
HUD and some major improvements under the bonnet, I may be changing my mind about my initial distaste with the exterior design
Wonder when the revised engine will appear in the Auris? IIRC, the Auris engine is assembled in the UK, so the line will have some alterations and a pause to introduce the new engine, if it should be allocated!
Revised engine..... I'm sure it said it was the same 1.8 lump currently being used?
Number of internal changes to the engine and transaxle are mentioned.
