My 2009 Avensis TR 2.0 petrol auto is due for it's annual/60000 service where it advises spark plug replacement. As the car has only done 37,000 is it worth spending £50 on a new set of plugs which are theoretically only about halfway through their life or shall I wait until the car reaches that mileage before changing them. My annual mileage is only 10,000s or so which would mean another 2 years before changing them. One piece of advice I've had is to have them changed on the grounds of age bu
For those who may want do their own servicing and wish to change the spark plug, here is what you need. If the wiper arms are seized on to the spindle, a puller/removal tool will be needed. I got mine from Machine Mart: https://www.machinemart.co.uk/shop/product/details/cht436-battery-terminal-bearing-puller The price was about the same as online and it can do varied jobs. Then you need a suitable socket of the correct size. Thank to "I", I got the correct socket which is a Laser 8mm 3/8 14mm
