Tte Coilovers Noise
ts507r
hi, i have an corolla Tsport. powered by 2zzge.
i just recently bought a TTE coilovers for my Corolla E12 (ZZ123). :rolleyes:
i just wanna ask, how do i know if my damper or the same coilovers is damage or is dead?? :(
actually i heard some strange sound with the coilovers, when i'm in movement :ffs: ...and another time i heard an horrible sound in some side of the car (left-right). but it just fixed sometime when i tighten the strut.... <_<
but it still have a strange sound. :help::help::help:
HOW I COULD KNOW IF MY DAMPER OR THE SAME COILOVERS IS DAMAGED OR DEAD??
ANYONE WITH THE SUSPENSION KIT??
*hear a very strange sound the i turn the steering wheel in movement.
*the strut of the coilovers is made by Eibach.
thanks
Just asking , what do have now ??
Only the TTE-springs or the complete height adjustable suspension kit :
2 weeks after build in the susp'kit I've got also noises from the springs. TTE said , just turn/srew the springs into another position ! (not the height !!)
And .... noises away :D
i have the TTE COILOVERS (complete height adjustable suspension kit)
*not the lowering spring*
sometime when move the spring of the strut, may go away the noise.
but later in a week it come back again..
any solution/
why happen that/?
the sound it's like the spring is out of place...
*should the rotor be tight in place, because my rotor seems very loose. when i take out the wheel and check it.*
i have the same setting as the picture showed....
lately i'll take some picture.
have you already screwed the spring into another position ?
I know it's sounds ridiculous ... but in my case it helped.
I had a squeaking sound from the springs , when the car goes into the suspension.
acidman:
did you have an email to make better the contact?
how do i move the spring into another position?
do i have to lift up the car or moving the bolt upside of the strut?
damn it make a crazy noise///
rickray@web.de
Don't know exactly if you can screw the springs without de-installation. (perhaps you can't screw it inside the top spring seat)
My garage do it. You can try it , lift up your car , remove the wheel , and try to screw it. Otherwise ....
Why don't you go to your garage and they should solve the problem. Or do you have installed the susp'kit by yourself ?
hi acidman...
tonight i checked all my suspension setup..
i take out the 2front wheel....
i checked the a kind of numeration of the strut that is:
LEFT <--------- (AM2004)
RIGHT ---------> (AM2003)
i move it to another position....and i'll checked it tomorrow at morning
also i'll post some picture.
thanks
These are for HB ... E12 too.
If U understand German, read PDF(TÜV/ABE)........................
(There is mentioned type:E12U-this mean that Corolla is from UK factory(E12T =Turkey, E12J =Japan).........and Toyota UK produce only HB Corollas..... :thumbsup: )......................
Nope, no german!
But thanks for the info! :thumbsup:
I called Eibach in the US and they dont sell the ones for the e12u :cacker:
Now Im fu...ed :censor:
Any other ones I can buy that will fit my car, and available in the us?
THANKS
EAVP....
hola como esta vecino.
soy de Panama....
tienes la opcion de escoger la suspension
TTE
TRD
TEIN
Eibach
H&R
todos son buenisimos
