Corolla EE80
jerry303
I have a 1987 corolla EE80 -  the hose from the heater to the thermostat housing joins on to a short metal connector - and the connector is leaking.
Does this connector screwout - should I patch it with a sealant ( plastic metal)?
Can any member advise  me?
On my photo I have marked the connector with white tape.
fortworth303@gmail.com
Would not think any sealant would stand up to the heat, pressure and vibration in that location.
Unless some local metal worker can possibly weld  it , though do not know if thats possible with alloy like that ?  - think your only way is a new part from Toyota or search the local and online scrapyards for one.
The colour of the dried fluid indicates a lot of rust in the water, a good flush at least needed.
Thanks for your info -  I'm still unsure if the connector will screw out - or after 29 years - will it crumble under pressure from the grips?
My local Toyota dealer have no idea - and I can't get a Haynes Manual for this car.
If any member know of an ee80 being broken - I will buy the complete thermostat housing.
my e mail is fortworth303@gmail.com
Assume when you say "My local Toyota dealer have no idea" you mean they do not know if its a screw in connector ?
Did they give you a price for the complete assembly ?
If not you could get a price from Kingo, a toyota dealer who helps out forum members, he might also know if the connector is screw in, but getting just the connecor might not be available separately via Toyota.
http://www.toyotaownersclub.com/forums/profile/34014-parts-king/
If no luck there then or too expensive for a complete assembly, then google "online scrap yard dealers toyota corolla" and get emailing them with you exact part /model  details and photo,
http://www.toyodiy.com/parts/
Have a look on here..might help you discern what the part looks like.
