t-sport matrix ECU / secondary air pump
g6r109
will a 2003 Toyota Matrix ECU work on a 2005 corolla t-sport?
I have the P0410 secondary air pump code and it does not want to go away.
I replaced the pump with a 2nd hand one this weekend that i tested before hand to make sure it was working which it was.
It turns on for about 30 seconds and was fine, but today the EML came back on with the same P0410 code.
I cleaned out all hoses and replaced the 50amp fuse but the code still remains. I am at a loss as to what the problem is.
So i am wondering would it be easier at this stage to swap the ECU's as I don't think the Matrix's had this stupid emissions system???? I am not sure on this
  • 2 years later...
Hi did you get a solution to this? I have 05 tsport and want to select the secondary air injection. Thinking an older model without it would work.
