How to remove front wiper arm - Aygo
kaliope
  • 5 weeks later...
I suggest yo apply some PTFE tape onto the wiper thread, makesit a lot easier when replacing the wiper  again!
  • 3 years later...
So....it's impossible to remove without a special tool? Handy....I'm changing the front springs for which I need proper access to the strut top nut, which requires removing the shroud/gutter plastic panels, which requires removing the wiper, and I need a special tool for the wiper?
Get real....
A standard small puller should do the trick, if they have never been off they will be corroded in place
yes you can get pullers design to remove wipers (body shops and windscreen fitters use them)
edit, pop the cap off and remove the nut and spray it down with something like GT-85 leave a few hours and repeat
https://www.youtube.com/watch?v=bQxlFT5SEqM
