GT4 Coolant issue
ChrisST205
Hi all,
apologies in advance but as you may tell I'm new to this. Recently bought a Celica GT4 ST205 (shes a beaut!). Anyway, I had a long drive, 400mile round trip to see the parents and on the way back the engine management light came on. I ran the diagnostic test and got error code 54. Found out im leaking coolant all of a sudden and at a rapid rate 2L overnight. Ive found a wet patch under the hose to the left of the coolant tank (right at the bottom almost touching the undertray) but to the right of the radiator itself. I cant find an engine bay diagram anywhere. Ive ordered new hoses for both coolant and radiator, once fitted do you think this would rectify the problem or should i look for something else
  • 4 months later...
How did you get on Chris ? The only thing remaining is the rad. Is the rad a brown colour, if so a new one should recitfy it
Sent from my Nexus 9 using Tapatalk
