fuel system warning light reset on Land Cruiser model year 2009
vandexa3
cheap thrills lyrics, one call away lyrics, heathens lyrics
Hello,
i have a Land Cruiser Model Year 2009 Diesel V8 Engine
and the fuel system warning light is on.
In the owners manual they are saying that this is the amount of accumulated water in the fuel filter has reached the specified level.
I changed the fuel filter but i don't know how to reset the light.
Does anybody know how to do it ??????
Thank you for helping me
bollywood ringtones
The warning light will flash on and off if there is water in the filter. If the filter is clogged the light will stay on.
I assume you have cleaned out all the old fuel and primed the system properly after changing the filter.
Two procedures to put out the warning light (according to Toyota Nation)
1. Disconnect top wires or plug on filter housing with the ignition OFF
2. Turn the ignition ON
3. Plug top wires or plug back in within 60 seconds
4. Turn ignition OFF
5. Turn ignition back ON and start vehicle
The light should now be off.
If the light is still on try bleeding the system again then go through above procedure to turn the light off.
OR try this:
1. With the ignition switch OFF, disconnect the fuel filter warning switch connector.
2. Turn the ignition switch from OFF to ON.
3. After more than 3 seconds but less than 60 seconds have elapsed, reconnect the connector.
4. After approximately 3 seconds have elapsed with the fuel filter warning switch closed, the
system confirms the deletion of the illumination information by turning off* the warning light.
  • 5 years later...
Hi
On the LC 200 Sahara twin turbo diesel 2016 I struggle to get the message deleted or reset. Every time I start up the message appears “fuel filter maintenance required”
I have tried the above “plug out, switch on and plug in” several times.
Cannot find any useful  advice on the net. Filter was replaced and housing cleaned properly.
Thanks Matt
If the initial problem was caused by water in the fuel tank being passed into the fuel filter; then it could be that you've got more water in the filter.
