Colorado gearbox failure?
shivasregal
Hope someone can help. went to start her today and engine just spinning. She's a 1998 lancruiser Colorado. When I put her in gear I can push her so I'm guessing gearbox has blown up?
Any  ideas where I can get reconditioned boxes
I think you need to get it somewhere to get it checked before assuming the gearbox.
Presumably you drove into the space where the vehicle is now so whatever failed happened overnight?
Does the Landcruiser have selectable 4 wheel drive or is it automatic / permanent 4 wheel drive? If you select 4 wheel drive try it and see if it moves.
Maybe someone has pinched the prop shafts overnight or the axle, differential, half shafts have failed. Could be many things.
Craig.
