I have reset the EPB and removed all the warning lights using the paper clip trick. The EPB now releases when the clutch pedal is raised to biting point and the throttle pressed.  Here are the details - Electronic Parking Brake fix.docx In case there is no access - Connect terminal 12 and 4 on obd port with piece of wire. Turn ignition on Within 5 seconds push park brake 3 times then pull 3 times Red park brake light will flash rapidly for a few seconds, t
    • Like
