CVT Transmission Fluid Change
Kuneha
@en8wall69 thank you for the update. Hope this will solve your problem. How many kilos or miles has your car already done?
40k miles. The 'box does seem a bit smoother although only driven it into work which is 12 miles.
Just done a 150 mile round trip and no gearbox whine when accelerating after coming off M25, which it used to do before fluid change so all seems good.   Fingers crossed.
  • 10 months later...
Im considering buying a 2012 yaris auto with FSH and 70K on clock...is it worth it ? do these CVTs last if oil is changed every 40k which it has ?
See
  • 3 years later...
