Electrical fault
aygo_rory
OK so I've got a random electrical issue and im at a total loss as to what's wrong. The car starts and drives although I haven't got any radio, power steering, rev counter or central locking, everthing else works fine. The fuses are all good, I've checked every single one and still no luck, the car was fine and has just randomly happened. Any ideas? Its a mk1 05 plate
Which fuses in what location have you checked?
Ive checked engine bay fuses and also the ones in the cluster inside. When I remove f1 on the cluster and put a positive feed into it with my tester everything works as it should which suggests its a short somewhere.
The car has sat in the back of the workshop for about 18 months so its probably been chewed up by mice
It suggests the opposite to me, namely that F1 has not got the required supply feed present. If you had a short on the output side of the fuse, then applying a 'positive feed' from your tester would simply short the tester.
after you spent so much time & effort repairing the car in your bodyshop
and then you just leave it there doing nothing , i thought you where going
to repair and sell.
  • 1 year later...
I thought I would update !
i know it’s been a while, well over 18 months actually but I decided a couple of days ago to have another look at the car and this electrical issue as I want to put it back on the road, after a damn good day testing fuses, relays wires and lots of swearing and frustration I have found the problem!!
i thought I would update this so if any fellow aygo owners face a similar situation  they will be able to see the exact cause of the problem.
i have attached a picture of what it was and it is located inside the engine fuse box!
maybe now I will have a bit more enthusiasm in sorting it again!
Wow, possibly a first? Never seen or heard of that fuse blowing before! Did you do any welding on the car? Or find any reason why it blew?
In all my years in the motor trade I’ve never seen one blow!! There was no welding done on the car when it went, it was a random incident.
I would be assuming that the alternator may have been to blame for that, luckily it was replaced.
Looks like il have to go to the main dealer to get a replacement!
