Water Leak Through Interior Light Fitting
dransfield
Hi All
I've got water dripping onto the drivers seat from the interior light fitting, has anyone else experience this and found the source?  I have a 2004 T25 Tourer.
Have had some entertaining electrical problems too but they seem to have stopped....
Coolant temp guage needle stopping working
Outside temperature -25 to -30 degrees
Battery charge light turning on randomly - Battery checked and healthy
Rear Window wiper turning itself on despite being off - have checked the motor on this (suggestion from an old post) and its dry inside
Aftermarket radio resetting to factory settings
Is there a hole in the roof above the light, Anyone added an aftermarket radio aerial to the car that could be leaking?
Sounds like water is getting in somewhere and making it's was down the wiring loom to the fuse box.
Craig.
A couple of members have found leaks from underneath the plastic trims that cover the panel joins on the roof (the black trims that run the length of the roof on either side).
Eg
Captain Tolley's Creeping Crack Cure -  https://www.amazon.co.uk/s/?ie=UTF8&keywords=captain+tolleys&tag=googhydr-21&index=aps&hvadid=155864605893&hvpos=1t1&hvnetw=g&hvrand=11513235874892028587&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045503&hvtargid=kwd-4887667420&ref=pd_sl_6kidvkfhod_e
1 hour ago, FROSTYBALLS said:
'Captain Tolley's Creeping Crack Cure'
Good stuff, used many times on cars & boats! :thumbup:
Hi, no after market aerial has been fitted, can Watergate in if the seals around the mounting points for the roof bars have perished?
