Yaris washer pipe
Jonburns
Hi all,
my wife has an 08 Yaris, 1.3 and the washers today just dribbled when she tried to use them. The motor is fine and water shoots out of the pipe before the little white connector that takes the pipe under the black plastic panel to the jets.
 I disconnected both jets and the water was not reaching them. I suspect either a blockage or a kink in the pipe. How do I get to the pipe, is it an easy job?
Cheers,
Jon
