ECU swap on a 2000 Avensis
AV3
Hello all
I am wondering if anyone knows what problems I will encounter if I try to swap my existing ECU for a second hand unit.  My unit has the following part numbers
ENGINE CONTROL 7A-FE     * 1757009314 *     89661-05220     MB175700-9314
If I use a second hand ECU with the same part numbers will the software be an exact match, accessories, transmission and the like. Does every software revision have a differant part number.
Does this Toyota ECU have a VIN identity, can it be overwritten.
Can I recode my existing keys to the new ECU
Can I use Techstream UK to reprogramme the ECU on a car of this age.
Sorry to be a pain, I have tried to answer my own questions, the internet is full of conflicting information on this subject so I thought it best to consult the community.
Thanks in advance
