Speakers In A Uk Twin Turbo 1994
mad welshman
hello everyone, ive just bought a twin uk supra. does anyone know what size of Speakers are in the door panels and in the back? i want to upgrade the system but cant get any info. please help. baz :help:
hello everyone, ive just bought a twin uk supra. does anyone know what size of speakers are in the door panels and in the back? i want to upgrade the system but cant get any info. please help. baz :help:
Pretty sure they are 15cm diameter front and back.
I would check but its raining outside. :lol:
Maybe later when it stops. :thumbsup:
Hold on, just found this:
The most straightforward replacement is a 4" speaker, (10cm). Even then you'll need to drill new mounting holes.
A 13 cm requires you to make a small mounting plate and do a little cutting of the OE speaker box.
17cm requires lots of modification or fabrication of a completely new speaker box. - Or, mount the speaker to the door card by removing the factory grille. - this is not the best way and if you take this route, be sure to dynamat the doors internally, get some foam/rubber gasket sealer to run around and seal the speaker better, and ideally make a wooden spacer to mount to the door card and angle it so that the speaker fires accross rather than down.
cool, what did you go for in the end ?
6.5" - R / 4" - F or 6.5" all round ?
hi peter.
went for 4" mb quarts components for the front, and infinity 6.5" for the rear. 2x12" subs in the boot. having it fitted at the moment. any ideas where i can get a reasonable priced blow off valve? instructions for fitting etc. cheer mw :drool:
I think you can get cheap BOV's but, don't know of any.
They are normally £200+ and you get fitting instructions with them AFAIK.
Some trader's who I have used before..
http://www.envyperformance.com/build.cfm?page=drill&cat=13
http://66.249.3.100/index.php?cPath=1_16&o...f3be967aa3911c1
http://www.whifbitz.co.uk/supra-bovs.html
HTH m8
Hi there- welcome to the TOC forum - always good to have another Welshman aboard
