Toyota avensis speedometer don't work
tonis766
Hey, i got an 2003 avensis t25 2.0 diesel 85kw 5manual, today the spedometer stoped working, no fault codes.
The first things I would  be checking are the instrument panel connector(s) and any earthing points associated with the panel. Security and corrosion of any of these things.
Sorry I can't be more specific to where they are located, but maybe a Haynes manual will help.
Fault code P0500 checked abs sensors, all working, the abs shows all the speeds correctly but speed signal gets lost
Now i got so much that from abs the wire goes into the dash and from there it goes to ecu. From abs to dash the wire is broken and into the ground. Where its broken cant tell...
