New Brake discs and pads
LOVEJAP
Hi All,
I'm after getting an upgraded or OEM like for like brake discs and Pads that are not from Toyota. Can anyone recommend a place? Like Pagid or Mintex. Any links. Toyota seems to be charger too much and I would rather be paying a little higher for better performance.
  • 1 year later...
you can try Brembo discs from carparts4less and brake pads made by EBC from eBay or directly from their website. The discs are coated against corrosion and the pads Ultimax series has very good bite in point, also they have special paint on them to help with bed in procedure after fitting.
Regards
Moved to the Verso club.
