Water @ the heating blower housing
Hannes
Toyota Avensis wagon T25.
Problem with some water thats comes in the housing of the heating blower motor.
The interieurfilter is dry.
Where to look to solve this problem from happening again?
Tnx
Have you checked that the drain for heater/AC casing is not blocked? The AC evaporator causes condensation to form which should drip out from the drain pipe if the pipe is blocked the heater box will quickly fill with water.
