Help corolla runs rough then dash lights flicker
Delta142
Does any one have any ideas as to why my car is a bag of carp lately. Started with car not starting so changed the Battery then the dash lights started flicking so changed the alternator then dash lights and faint Battery light so swapped alternator for a better one now it will run ok for a while then lights will flicker engine runs rough and starts to miss whilst driving and when you turn it off it will not start until an hour or so later any help would be appreciated don't know what else to do.
Are you changing the parts for second hand ones,    have you had any electrical tests done on the Battery and alternator ?
No new Battery then I had a new alternator which I then swapped for a new Lucas one trying to get to a auto electrician in the morning only started after I had new coils fitted whatever thanks oldcodger.
Just to add the exterior lights , radio etc work fine and once the car has been left it will start first time so it can t be the alternator or Battery thanks oldcodger.
On 8/4/2018 at 11:48 AM, Delta142 said:
Does any one have any ideas as to why my car is a bag of carp lately. Started with car not starting so changed the battery then the dash lights started flicking so changed the alternator then dash lights and faint battery light so swapped alternator for a better one now it will run ok for a while then lights will flicker engine runs rough and starts to miss whilst driving and when you turn it off it will not start until an hour or so later any help would be appreciated don't know what else to do.
Hmmm, perhaps try all earths for good contacts, then all fuses for good contacts too
It my help to state your exact car details- so what year, engine, gearbox ......
It's a 2005 1.4vvti manual could be right I'm booking in with a auto electrician tomorrow will let you know asap thanks
Have you checked the IAC valve? That can get clogged, its attached to the bottom of the throttle body.
Car all sorted now it was a bad earth on the engine thanks for your replies.
