Rear brake pipe coroded nct failure
mark0
Lads just failed nct on rear brake line extreme corrosion on avensis on both sides . The tester said it was handy enough to do that it is behind the wheel arch you can’t see it that I will have to pull the wheel arch cover down to see it just wondering whats involved
