Low power
StenNorway
I bough a Rav4 with turbo leaking oil. Changed the turbo, butt the car would not pass 3000rpm. Read all post on this forum. Blanked egr, cleaned maf, removed dpf, New scv, cleaned turbo valve. Nothing helped. Then i took out the catalyst under the middle of the car. Now i runs like a train all the way too 5000 rpm . Thougt it might be a tip tho all that struggles with power loss. (sorry for my bad English)
Wow!  Did some angry neighbour shove a load of barbecue fuel up the exhaust pipe?
In the UK removing the cat would be an MOT(annual vehicle test) failure, especially given the changes introduced in May.
so would removing the DPF.
I am surprised that Norway would allow this with their environmental legislation.
p.s. welcome to TOC, Sten. 🙂
Removing the cat would mean that you'd fail the MOT here in Norway as well. I think he meant that the cat might be the culprit if you have these issues, which means a cat replacement, not removing the cat permanently.
It is one year to next test, but if it not pass i Just pick up a new one from the junk yard. There is no Black smoke from it. Probobly because it now runs with 1bar turbopressure.
  • 1 year later...
Thank for the tip. Just bought a 05 with the same issue, gone beat the hell out of the catalyst and see😜
Thanks,
Raymond, another member from Norway
Hi, is this what happens when you only do low mileage, it breaks the cat, as you have to do a longer trip so the cat can burn off the crap that’s in there. I remember reading that people where having to spend £1000s  to change there cat because they were only doing low miles per week?
You don't have to do long mileage, but you have to give it a Italian tuneup once in a while, 20-30 mph trip in higher rpm's.
