Cam lift/redneck 'heel' cutting ??
tooSavvy
Hi.... thinking outside the box here....
If I wanted to increase lift by 1MM on my 4A-F inlet camshaft, would taking the cam and mounting it in a jig allowing 360° rotation THEN reciprocating around the Base Cicle [linishing only the circular element - stopping before touching the flanks] with a 13MM belt sander [solidly mounted relative to the cam axis] would I get a smooth 1MM removed = 1MM increase in lift?
Thicker shims / custom obviously to reset lash.
I imagine breaching 'hardening' skin would be an issue, but more so in the flank/ramps. ??
2sav
Have you checked if it can be ordered online, as a complete part?
You can probably have someone turn this in a lathe and remove necessary amount of metal.
Problem then would be wear and tear on it.
