edwardttbann
eddiettbann
hi all, new to this and am grate full for allowing us in Botswana to be assisted, I have a Toyota surf 1kzte auto, it pulls off in 3rd gear every time I stop.I am an auto electrician by trade, I also fit after management systems for petrol engines and after market transmission systems.I have checked the following and come down to the conclusion that it has something to do with the tcu, there is power on the cable the the gearbox to energise solenoid number 2 which in turn is for gear number 3, if I disconnect the three pin connector from the gearbox and energise sol 1, gear one will engage, all the gears working fine when energized manually, from the tcu only pulling off in gear 3. no engine light, please assist
