Corolla1.8 tsport ideas?
Lewi.corolla tsport
Just looking for general advice on what I can do for my corolla t sport. I’d like to sharpen the steering I’m going to install a set of coilovers and don’t cheap out on tyres what else can help me in the corners and what can I do to add bhp sensibly that’s not going to end up ecking the engine ....I’m going to go to stainless creations to Upgrade the exhaust, as well as I can to uk road legal standards. Thanks
Moved to the Corolla club.
Yes do the exhaust you wont regret it. I had all the old system off since it was the original from 2002 and began blowing last year up at the exhaust header/manifold join. I had a custom setup done in stainless and oversized by 0.25 of an inch over the stock diameter. I kept the original cat for emissions and no check engine light issues along with a stainless resonator/silencer just as it looks on a standard setup. I currently have no back box/rear silencer and it does sounds superb, I will be getting the system finished off soon so I'll try and get a video of the car as is now and when its complete.
For handling on a budget there is the Tein street basis like on Fensport and it uses a combinations of new parts and some that are already on the car. Note the most coilovers are pretty expensive for the Corolla.
If you are on a pre-facelift you can take the front and rear strut bars from the facelift to help stiffen the car up I keep meaning to do this myself. For tyres I just have the standard T sport wheels with the Toyo Proxes TR1 and they have been fine for me.
I've always seen mixed discussions/arguments on the engine modification side of things especially things like air filters on the 2ZZGE so I tend to spend my money on maintenance rather than mods. First things I did was change my lift bolts, get the oil and filters changed etc. I did the seafoam intake spray treatment also.
Also if you serious on improvements one area would be the brakes! I really need to overhaul my brake system with some Wilwoods on the front and just renew or refurb the rear calipers, brake lines and master cylinder...
One thing always worth doing to tighten up the T Sport is to put polyurethane replacements in everywhere for rubber ones. Quick and easy job, but makes a BIG difference to the handling by stiffening it up.
