Hi I dont know if this has been brought up before, but basically my aircon compressor is making noise at idle and when driving it gets quite loud. No gas in system as the condensor has a leak, so Im guessing bearings are bad from running dry.
Is it possible to remove the aircon unit and bypass that pulley by using a shorter drive belt?
If so does anybody know what size belt is required. The engine code is 1AF
