Paint damage caused by goalkeeper gloves!
Looks like a perfect job for T-Cut in the first instance.
Farecla do a range of abrasive polishes if you want, say, a finer abrasive (Farecla G10, for example), but it's more expensive and not so readily available.
Maguire's do two levels of cutting polish.  That should come out, even if you have to wet sand (read up wet sanding on detailing world).  Otherwise a professional detailer body shop will buff it out
