Toyota Verso-S (Terra) / petrol 1.33 - Cruise Control add on
Joseph07
Good Day everyone,
I was wondering if it's possible to add Cruise Control Stalk into my Verso-S petrol engine car.
I have a Toyota S-Verso 2013.
Does any of you have tried to install Cruise Control Stalk in his car.
I was able to find some answers on the USA forums but the info is not relevant for EU cars, only USA cars, mostly for Toyota Corola. or Yaris.
I was able to track the P/N Cruise Control Stalk
Also some installation instructions for Yaris OEM Cruise Control Installation
I don'y know if it's going to works with the S-Verso.
Any ideas are welcome.
I don't want to start  "playing" with the ECM connectors (re-wire to the ECM unit) I was hoping for plug & play solution.
Thanks,
Joseph
  • 5 months later...
good question mate. I would like to know the answer to that too.
  • 7 months later...
id really love to know too if this is possible. I terribly miss a cruise control on my car
I cant see it being much different to the yaris, A quick google for Ractis Cruise control .................................
Hi Guys,
Any update on this topic? Have anyone tried to install the cruise controller by himself? Or should I bring the car to the specialized garage?
Hi Michael,
I just installed the cruise control stalk on my 2012 Verso S. Unfortunately I was unable to get the "cruise" light on in the dashboard.
I dismantled the top and bottom covers behind the steering wheel: it misses the two wires (ground + ECU).
I also tried looking for the ECU connector (see if it is similar to Yaris/Prius): no success so far.
Source:
PP
  • 10 months later...
On 4/18/2020 at 11:35 PM, philpeter said:
Hi Michael,
Source:
PP
Hello philpeter. I am searching for a cruise control for my 2013 toyota verso-s 1,4 d-4d diesel. I did not find any cruise control stalk. Is it possible to add one for a diesel engine?
Hello Fellow Seekers,
I am also still searching and searching for where to connect this one wire to the connector of the ECU.
I am also still  unable to get the "cruise" light on in the dashboard.
Hope to find it here some day...
Greetings, Walter (reclamegezeik@gmail.com)
Does it work though even without the cruise light?
  • 9 months later...
there is a japanese video i think it worked but it depends what chasis we have NSP120R i have
Hello,
I installed  84632-34011 8463234011 45186-0D110-C0 /E0  Cruise Control Switch 84632-34011 84632-34017 in my verso s 2011 model, but still dot work. I don't know why.
On 7/20/2022 at 2:53 PM, 5ilvio said:
Hello,
Any update on this? Did you figure it out?
If it's the 1.33 not all ecus support cruise control. There is no programming in the ecu for it
2 methods
1.physically check that you have the correct clock spring and wiring in place - If you have audio controls, you usually have the correct clock spring, check that you have the correct clutch/brake switches
2.Use techstream to verify the control/ecu function
info from a mk3 yaris using TS
No CC
A156E3EA-D606-43DA-B8D4-A4D76F14E1B9.jpe
With CC support
54B4A542-BC9C-42AD-A913-469A3B1DCC3A.jpe
Very helpful, thank you!
Is it possible to check for the above via the generic cheap bluetooth ODBII devices?
Also, what do the clutch / brake switches look like?
The above information (PID's) can only be seen in TS or some higher end scan tools - there are TS Chinese clones available with the Mini-VCI interface
As for the switches, i couldn't tell you what are used on the Verso S configuration
Where on the dashboard is the light for the cruise control? Didn’t find any in the manual, can’t see it with a flashlight either.
It seems some ECU dont know there is a serial or something u can enable this.
but will investigate
Quote
Ok there are different versions of this car
this is actually similar to YARIS NSP120
t Spirit 1.33 NRFE
Normal trim
diesel
The t spirit one has the clutch switches installed similar to ractis
i think you may be mixing up your models
1.33 - 1NRFE (petrol)
1.4 - 1NDTV (Diesel)
Sorry I meant to say this NSP120 have different trims the one I have has the clutch switch installed and its 1NRFE
There are 2 types of clutch switch - the ecu uses it for many different systems, including SRS
yours was built 03/2011 cruise wasn't an option until 12/2012
