2011 Verso Central locking Lock's but wont Open?
Buzeasby
Hi.
I have a 2011 Verso where the Central locking wont unlock the car but will lock it.
The key fob switches off the alarm then I have to use key to get in, then manually unlock all doors. The internal door lock/unlock switch also does not unlock the doors.
The key fob will then Lock all doors when required as will the internal door lock/ unlock switch and the doors auto lock at 10/15mph as normal.
Any ideas please?
Jon
Moved to the Verso club.
On 11/27/2018 at 9:39 AM, Buzeasby said:
Hi.
Any ideas please?
Jon
I have my verso set to auto lock and unlock, mines set to unlock when in park, it's not a cure buy it should help until fixed, I'd start by checking the appropriate fuses, is it possible your fob is faulty maybe get or try a second one
  • 5 months later...
Did you get sorted this issue please advise if you have I have same problem
Edited by FROSTYBALLS
Mod edit: please do not use textspeak
Try replacing the key fob Battery. This happened on my Yaris.
  • 1 year later...
I am having the same issue and its not the key fob as I have 3 and they are all not unlocking the car but will deactivate the alarm. Did you solve this if so how ?  Please
  • 7 months later...
I have a manual 2011 Verso, the doors lock at speed then won’t unlock. I have tried the instructions in The Manual but they don’t seem to work.. can anyone explain it to me please?
  • 1 year later...
Im having the same problem, did you ever find out what caused the problem?
