Stolen Keys - Toyota Aygo
GlenUK
Hello,
I have a Toyota Aygo platinum 2008 5 door model. It came with a key/remote fob and a spare key (no fob on the spare for central locking). Today someone stolen the main key (the one with the remote fob). I have parked the key some where safe in-case they return for the car.
What are my options now? I guess I will need to get all the locks replaced on the car? Any idea what the cost might be? Really skint with it being xmas.
Thanks for any advice!
you will need the stolen key to be deactivated from the ecu so it cant be used in the future.
sorry dont understand your quote at the top
Wont they still be able to use it as a standard key? The doors have locks the key can be inserted into (mechanical locks), the ignition is mechanical also.
Also, do you have any idea of the costs involved?
Many thnaks,
Have you checked your insurance policy to determine whether you're covered for lost/stolen keys?
Won't I lose my no claims?
You would need to check with your insurer to be certain.
I just checked. They cover the cost if they were stolen from outside the car. Mine where stolen within the car.
Many thnaks,
based on you saying you where skint i mentioned the deactivating the key as its the cheapest option
and this would stop your car from being started as the key has the immobilser chip in it,
if you want a 2nd hand set of locks with keys and the alarm ecu then budget for £300 - £350
then its a straight swap if you dont have the alarm ecu you would need the new keys programming to the car.
Yeah, I called someone and they said they could deactivate the key for 170 quid but they'd still be able to get into the car.
He said I'd need to contact the main dealer to have the locks replaced, is that true? Or do you know if someone that clukd do it cheaper?
Many thanks,
1 hour ago, eygo said:
just found this for you glen
all you need to do is buy a spare key
Thanks, would a garage fit that for me?
a garage would do it for you but
honestly it is something you can do yourself
once the door panels are off the barrels have
a clip to hold them in and the ecu is plug and play
i would just have a look around the web to see if you
feel you could do it yourself
Okay, plot twist. I got a call today for a woman who found my keys (bear in mind they were taken from the running car yesterday) I went to meet her and at the end of the street was a young teenage lad waiting to hand me my keys. Reason I mention that is I'm pretty sure the young lad took the keys to show off with his mates then his mum found them and called me.
Surfice to say, I have my original keys now. Is there a way I can reprogram the keys so that a copy would not start the car? I highly doubt they made a copy within a day but just incase?
the kid may of had a key cut but probably wont of
getting the immobilser in a day isn't possible and
you also have to prove to toyota ownership of the car
before they will supply the immobiliser part.
here is just the lock set you could change the locks just to
have piece of mind,on the remote key there is a small
screw undo this screw and the key blade will come out
you can then swap the new lock set blade into your original remote.
https://www.ebay.co.uk/itm/2010-Toyota-Aygo-5-Door-Hatchback-Vehicle-Lock-Barrel-Set-With-Key/163425767571?epid=22026969346&hash=item260cef5093:g:xGYAAOSw8OFcD4wS
Okay eygo, thanks pal you've been a legend. I may have a stab at replacing the barrels.
Just to confirm, if I assume the worst that he did get a key cut, without the immobiliser they cannot start the engine but they can open the car door?
yes thats correct can open the door but cannot start the engine
