Mystery plug.
ferrispedro
On inspecting my "new" car 2003 2.0GX I spotted an unplugged  connector in the engine bay lose to the Battery. I connected it up and nothing seems to have changed. Any ideas?
Any chance of a photo of the connector? Do you have a test meter?  A bulb with 2 wires soldered to it will do to check if there is a circuit there. place one end of one wire on the positive (X) terminal on the Battery and the other on the connector.If it lights it will show that this is a earth wire (-) If it remains unlit that shows that it  could be a redundant wire. Any chance of following that wire to it's other end Is it a single connector you could try a little pull to see if it is connected.
Del
Edited by crofter
misspell
Sorry for the delay, photo added. If you blow the photo up you can see the white plug in the centre.
