2009 Aygo "Blue" mechanical rumbling when driving off?
Kangaroo1
Hi all, I've recently (perhaps a couple of months) noticed a slight "sort of" rumbling noise coming from the near side front when I pull away, from start up. Once I get moving it disappears and a minute or two into my journey I don't hear it again, even when stuck in the usual stop/start traffic. To be honest I've always wondered if it might have been exhaust related, but this morning however, it was quite a bit louder, certainly noticeable & now I'm certain that it isn't exhaust related, because it definitely sounded mechanical! Again though, once I was a minute or 2 into my journey, it went away & I never heard it again.... The car's been sat outside my office all day, so I'll check it again when I leave for home, but in the meantime, does anyone have any ideas what this could be?
Thanks in advance!
Hi............would you be able to say...........does this noise happen when driving (accelerating) or braking?
Hi Colin, the noise seems to be there only when accelerating.
I wonder if it's some sort of gearbox/engine bearing, grumbles when cold but goes away once the oil warms up. Big end maybe?
Hi Ben,
Thanks for your feedback. A bearing is quite possible, and would certainly fit the symptoms.
Not big ends though... I've had big ends go before, on an old car I basically ran into the ground, many years ago (in the 1980's!!) when I was a lot less sensible, and the sound is definitely different.
Thanks.
