Better throttle sensitivity
Chris McGlasson
Anybody know how to make my throttle response sharper, any modifications to the motor or anything i can do, any help will be appreciated.
Short of hacking the system (specialist ECU reprogramming) I would say no. It is how it is in order to maximise efficiency and minimise emissions. The fly by wire throttle can feel remote and distant compared to older cars that had a direct throttle linkage.
Right aye no bother always the same with this car 😂😂
hi chris
this will improve the throttle response to the point it will feel like a different car
https://www.diesel-performance.co.uk/tuning/car/toyota/auris-from-2006-to-2012/1-4-zze150_-97ps71kw-1398-ccm/#go
this company supplies parts for petrols as well
i have used one of these on my car and its fab
will look into this,every little helps is suppose
you dont get anymore HP from the car with the pedal box
it just makes the car more driveable, once you turn it off
the car feels dead and you wonder how you ever managed without.
the pedalbox has 4 modes ,city,sport, sport+ & stock and each mode
has 7 settings(except stock) from the middle setting you can go up &
down 3 increments
there is a function called perfect tune and this tunes the pedalbox to the accelerator pedal
personally i leave it in sport+ and +3
you can try with sport Air Filter replacement for your original one, does help a little bit without been too expensive, but you can’t expect a huge difference , just slightly more responsive and louder engine at higher rpm between 3000-5500
  • 9 months later...
Got the filter with silicon pipe fitted, got a exhaust I made up on to, gonna take the car out and replace with sports car I think
