Puff of blue smoke
jeff juke
Hi guys how is every one. As some as you know im a disabled driver and my car dont get a lot of motorway driving however,its been about
6 months maybe longer since i gave it a good run as its mostly short trips it does. I was on the motorway last week and i was cruising at 60
for about an hour.I came off the motorway and came down to a roundabout to which i had to give way to the traffic on it.I got a chance to
pull out and when i did there was a large puff of blue smoke which i saw in the mirror,then it cleared and when i accelarated again there was
another  short puff.On the way home the car was fine,no blue smoke at all, even when i booted it in sport mode.Oil level is fine so no worries there
so i was wondering if it was clearing the Sh#t out the engine due to the short runs it had ? I await any answers thanks in advance.
Hello Jeff,
Which model and year do you have, and it's it petrol or diesel?
Regards
Ian
Sent from my SM-G965F using Tapatalk
Soot can indeed build up in a cat that does not get hot enough to burn it off, I know peeps who had the same problem on a MOT test and was told to have a good run in a in a middle gear on the local M1,  that did the trick
Given what you've said I wouldn't be too concerned...but keep an eye on it and do regular oil levels checks.
2 hours ago, fugly said:
hi it could be valve stem oil seals
If it blew blue smoke at each cold start up......perhaps.
Thanks for all the replies guys.Oil level is fine and no blue smoke on start up this morning.
Car has only done over 55000 think i will give it a blast down the motorway more often.
Thanks again....
A 2010 2.2 D4d Auto will be a D-cat engine which has a DPNR fitted blue smoke can be a sign of poor or failed regneration attempts
