Aygo replacement discs and pads
blackpoolskier
Leverage - I used impact socket and an 18" lever. We've also got an impact gun, but didn't use that.
On 6/30/2022 at 2:26 PM, flash22 said:
Inspect and clean the rear drums, It's either the rear shoes or the cable has stretched, what is the actual wording on the fail sheet ?
Mk1 or Mk2 aygo ?
Hi managed to do my pads and discs this morning with lots of wd40 and a long bar on the socket thanks for all the suggestions from everybody.
  • Like 4
On 6/19/2019 at 7:53 AM, mickburkesnr said:
To be fair, I've always done the brakes myself, but there's a torx screw on the disc that is a proper PITA to remove especially when (not if) it strips. If I took it to the dealer I'd fully expect to pay £150 just to take that damn screw off!!
Thanks for this tip , I banged a hammer with screwbit on it with some oil , with a little ratchet came off a treat 🙂
