Thazaras
Hello will r17 7,5j et 38 be suitable for avensis 2002 d4d. If yes what the best tyre size?
is that a T22?
if the wheelfitment.eu info is correct then the wheel that you linked has the wrong centre bore but at least it is larger so you may be able to get an adapter. €40 is very cheap.
And   think the best tyre size is r17 205/40
speedo will read slightly (~3%) fast with those tyres & it probably already reads fast on standard tyres. Not to mention the harder ride & increased potential for sidewall damage.
