Dash LED's
iGooooo
Hi guys!
I'm thinking about changing the colour of the interior dash lighting, and wondered if anyone has had any experience changing these before, AND, what the results were like?
I've seen some kits online... any recommendations or advice?
Cheers
3 hours ago, Planemo said:
Thanks dude. When you mention soldering work, how much was involved? Also, I don't suppose you have the link you used for the fitting instructions from the 107? Cheers
The multi pin plug takes a bit of care as mentioned in the thread, and the small surface mount leds are not easy to solder. I have been soldering for many years and I found it a tricky job but no special surface mount soldering tips required.
Heres another fitting thread following a google search:
https://andydoz.blogspot.com/2016/08/citroen-c1-mk-1-peugeot-107-toyota-aygo.html
  • 10 months later...
