2013 Dash and door speaker replacement
iGooooo
Hi guys,
Bridge the connections for the dash tweeters otherwise the door Speakers won't work! Finally solved the problem after much head scratching.
Drivers side - Red/Blue = Positive, Green/White = Negative
Passengers Side - Purple/Brown = Positive, Pink/Black = Negative
Couldn't find any hints on this forum (maybe not looking hard enough) so thought I'd leave this here in case anyone needs a steer!
