Wheel Offset
Tomfromfife
Does anyone have information on the wheel offset on the 2019 RAV4 Hybrid with 18 inch wheels?
Maybe 35 or 45 ?
Yes, I tried that site but the offset figure is missing for 18” wheels. 17” is ET35 and 19” is ET40
If you use anything between 35 to 40, or even let's say 42, you should be fine.
Only issue you might have is if the tires are too beefy,  they might  rub on the inside, or when wheel is turned full either way.
Does anyone have a full size spare wheel as the offset may be stamped inside the rim. I want to buy a full size spare but maybe not a Toyota wheel as it’s only the spare. I want to ensure I buy the same offset as the road wheels.
I looked at my new alloy wheel for my 2019 RAV4 and stamped inside the rim on the back of a spoke is 35 BKR so I guess the offset is 35.
