Picnic shocks
cresad
Hi all
Hopefully I'm posting this in the right forum , I couldn't find one just for the picnic's.
I'm trying to find some air shocks / load levellers for the rear of mine , I do a lot of towing and find them very useful. I've had them on my cars for the last 30 years but can't find any for the picnic. I've found the Monroe number - LA494 Load Levellers , but even Monroe can't find any left available. Does anyone know if there are any other Toyota models that have similar rear shocks that I can try and find shocks for ?
Thanks , cresad
In some markets the Picnic was also called the Ipsum - so may be worth searching using that name.
Also Called the Gaia in some markets but beyond these 3 renames of the same car the shock absorbers do not share with any other Toyota
If you know the part number a quick search should locate the part and models that had it fitted.
As Paul says...get the part number ...and either megazip or toyodiy should be able to help you identify those.
Having your frame number handy will help.
Toyota part number 48531-49115 x 2 they are not sided
  • 2 years later...
Thanks for the help
I think I've found that the sienna in the usa uses the same part number suspension as well
