Aygo spare wheel
Si yaris
Hi just got a yellow 2016 aygo 1.0 .can you fit a normal alloy wheel in boot where the spare wheel should be or is it only big enough for a space saver wheel
A full size spare fits in the boot. And an alloy will fit in there.
Great didn't know what to buy have you got one in yours cheers
Do you need to change your profile
No I just have the normal steel wheel that came with it. But years ago I was driving back from Budapest I had a flat tyre. I didn't trust the place I was in, so I swapped my alloy wheel for the steel wheel. Because we had luggage and stuff I put the alloy wheel back in to the well and covered it back up. The only issue you'll have is the centre cap as it needs to be removed I think.
