Auto transmission filter Previa 2.4 2AZ-FE
2005TSpirit
Would anyone have a part number for the filter, gaskets, etc. required to swap the transmission filter in a 2.4 Previa please?
Moved to the Estima club.
Maybe your local Toyota dealer could tell you.?....having your full frame/VIN number will help.
Thanks. I'll check the numbers. Would you know if it is necessary to change the filter at the time I'm changing the fluid?
