Apple Car Play
sigimimoo
is it possible to retrofit Apple car play to a 2016 toyota aygo?
No. Some versions of the 2018 facelift Aygo have a different head unit which can accommodate Android Auto and Apple Carp!ay.
2 hours ago, sigimimoo said:
is it possible to retrofit apple car play to a 2016 toyota aygo?
OK thanks @FROSTYBALLS.  Instead, if i replace the current basic dab radio (pictured) in my 2016 toyota aygo with this one (also picture), can you forsee any problems?
No problem - but you still won't be able to get Android Auto on the pictured X-touch head unit. The updated X-touch (compatible with Android Auto) fitted to some versions of the facelift Aygo can be identified by having three control knobs rather than two.
Conversely I have an android phone. However you should be able to connect via bluetooth or cable. Depends what you wish to do. Apple Carplay won't work though as per my last post.
