Wiring Question (A/C Amplifier Assembly)
wkcr89tec9
Hello all,
I am trying very hard to fix my A/C and I have found several forums linked to this exact problem.
Can anyone out there read wiring diagrams?
I have a 2012 Scion IQ (North American) and I am trying to determine the 3 wires (live, ground, flow sensor signal) that are coming from the Flow Sensor atop the A/C compressor going to the wiring loom that plugs into the A/C ECU.
On Page 2 I see SOL+ (Red PIN 13), FLOQ (Sky Blue PIN 4) and SG-1 (Violet PIN 23). Which I believe are the 5v live, the flow sensor signal and the ground in that order but I am unsure.
Hope someone can help!
EWD IQ.pdf
Here is a complete guide to fixing my A/C. It is a bit overkill.
https://workupload.com/file/SrWkgPjV
(175mb compressed)
(175mb compressed)
Hi James,
I can't open this file, is there anyway you can send it over again please? ....
Thanks,
