Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
remon1496
10 hours ago, mildg said:
Thanks,
Do you think if i remove cable "D", it will work? Because the USB cable is still plugged in.
No, you have to plug the USB directly into the head unit.
It's nice to see you guys fitting the new model in your cars. Glad I've been able to help.
I just upgraded mine to the new 3-button model a few days ago, and I used this thread as a good idea of what to expect - thank you!
Hello, guys
I was reading this and other forums before to decide for the new unit!
Really it was a good decision and the CP function is pretty useful!
I got the 86140-YV020. Does anyone know where getting firmware updates from?
Mine before and after.
Quick question - are you people also experiencing a slow response when skipping audio tracks using the steering wheel buttons? I need to wait probably 2-5 seconds between skipping, else it'll just ignore my skipping if I use the steering wheel buttons. I can skip as much as I want if I use the actual touch screen skip buttons.
It also seems to do a reboot every blue moon (like once a weeks worth of use? its not an issue tbh, purely wondering if anyone else has experienced random crashes)
On 11/4/2021 at 8:03 PM, flash22 said:
what is your software version ??
It says:
Audio: 8.11
OS 1: 1.10
OS 2: 1.17
Is it possible to update the CarPlay units?
2 hours ago, Chris Boddum said:
It says:
Audio: 8.11
OS 1: 1.10
OS 2: 1.17
Yes it is.
What is the Hard No. Found in.............
Setup - General - Software Update
OS 1 And 2 look odd
go in and out of this menu a few times and see if os1 and 2 change, OS1 and 2 should read 8.1x (x is the last digit)
1 hour ago, flash22 said:
Yes it is.
OS 1 And 2 look odd
That’s totally my bad, I misread the details, it’s:
OS1: 8.10
OS2: 8.17
does that sound up to date, and how exactly do I update the system?
thanks!
It must be an early unit, I have the 8.14 what is the 2019 update for no audio and reset issues, i will drop you a PM tomorrow
That would be very kind of you. It’s weird, the seller told me it was a 2020 unit (so are we going by the 8.10 or the 8.17 in relation to CarPlay? I’ll upload a picture in a moment to make sure all the numbers are correct)
Just an update: I updated the unit thanks to flash22's PM. It was a bit of a frightening process, as the unit would black screen (at the correct times), but after a few restarts, it all seems to work. I'm interested in seeing if that cleared my restart issue. It seems like both my previous OS2 and the new OS2 were 8.17, but I guess we'll never know if they applied some small changes to it.
Sorry, man.
I didn't see your reply. Just I was reading you helped a guy with a PM.
Could you send me also that message?
According to my unit, it says:
Audio: 8.10
OS1: 8.10
OS2: 8.14
Thanks in advance!
Edited by jigutierrez
Changed the picture
Hello
I managed to find on eBay a 86140-YV020 screen to replace my 86140-0H010 on m'y Aygo 2017
No difficulty to assemble it, it goes pretty fast.
But on my old 86140-0H010 there was no DAB connector in the wiring harness and in fact this does not exist on the screen see photo
It is quite peculiar square plug for a coaxial cable as the FM plugs are not standard.
Are there any adapters to install a DAB antenna?
Thank you in advance for your answers and congratulations for this forum the only one that really talks about the Aygo
On my 86140-YV020 I have the software version :
Audio: 814
Operating system 1: 8.34
Operating system 2: 8.59
Is there a more recent version and how to get it?
Audio: 814
It seems you have to give us the answer haha.
I did the last update from 8.10/8.10/8.14 to 8.12/8.15/8.17
Hello,
I am also interested in the latest version, I have currently version: 8.10-8.10-8.14
2 hours ago, Roger75 said:
Hello
I managed to find on eBAY a 86140-YV020 screen to replace my 86140-0H010 on m'y Aygo 2017
You either need to change the Aerial and cabling, the Triple play is produced by pioneer
iirc the DAB plug is a HRS GT5 if not its a JAE connector
What is your location ?
33 minutes ago, kachel said:
Hello,
i will send you a pm
35 minutes ago, flash22 said:
8.14 was released 09/2021
i will see if i can locate it
It would be great!
Many thanks
Thank you for this information
Now yes change the antenna why not if I find the right wiring and especially connector but is it complicated?
Without instructions on how to disassemble the fittings it must be quite tricky I think
I live in France
