Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
remon1496
On 9/27/2022 at 5:20 PM, jefjb said:
Do you see, when you switch on and switch off your light, a brightness difference?
And this difference is big or small?
So, i saw that:
- without light, we can adjust brightness for the screen in camera mode and in classic mode
- with light, we can do the same
after doing this, the sytem switch between both mode according to switch on/off the light
so it is OK for me.
But when i use Carplay, ths screen does not switch in dark mode when i switch on the light…
how can i do?
Is it possible to send me the upgrade for:
tripleplay 86140-YV020 As well. For some reason my dab and FM are working, but my navigation is old. (Foto included) and my CarPlay isn’t working. I’ve also placed a picture of the toucheren I have: please help me to fix CarPlay from Apple.
tripleplay 86140-YV020 As well. For some reason my dab and FM are working, but my navigation is old. Last update 2017 and my CarPlay isn't working. Not knowing why: because it’s the same one:
model 18PPDAEU-EA01
86140-YV020
tripleplay 86140-YV020 (systeem)
What unit do you have, the tripleplay does not have built in sat nav if your car is a 2020 it will not have a 2017 x-nav map
can you please post your current software version
model 18PPDAEU-EA01
86140-YV020
Gps ublox v7. 03 (115200)
SDID 3wpp 3Y37 TY9H FHWE 33C9
Ah you have an aftermarket sat nav (Chinese android module) - tbh i didn't even know they did them for the Triple play
is that something you fitted ? have you had the car play working at all ?
No. The CarPlay did not work. I’ve got the car registrate at 2020. But I’m not sure when he is made (car from work)
it was already in the car
I’m not sure if this is the final update.
carplay should be working, if I’m looking at the manual. It isn’t working when I do plug in a usb portcable. For android it is working:
I will attach a file, not sure if that’s the one I need for the update. Do you know that?
105290994_13TPDAEU-EA01_0003(840version).zip 200A_RC2_VERUP_MANUAL_rev1_00.pdf
On 2/10/2022 at 3:54 PM, Roger75 said:
On my 86140-YV020 I have the software version :
Audio: 814
Operating system 1: 8.34
Operating system 2: 8.59
Is there a more recent version and how to get it?
Thank you in advance
How did you get this update?
mine is saying this (picture)
I’ve got no CarPlay working. do you know how I can enable it?
Please be patient, i do not live on the forums (tho it seems like it) nor do i have anything to do with the running of the forum, this is just an interest/hobby
you have an aftermarket sat nav module installed, this will not allow CarPlay to work as they are not compatible with each other
2 choices
1. carry on using the sat nav
2. remove/disconnect the sat nav module, making sure to plug the usb back into the radio from the sat nav harness/wiring
This is not a firmware issue
the 2 updates above are for the X-touch only
Sorry if I did make you feel like I’m in a rush.
do you know how I can disconnect the navigation? It’s not up-to-date is it’s better to use CarPlay on it, giving me more correct navigation.
if I do remove the navigation from the system. Will CarPlay be activated?
yes, remove the nav, and the CarPlay should work
the sat nav wiring will be behind the radio, the nav box will be behind the stereo or glove box
there are plenty of vids on YouTube on how to remove the radio from the mk2 aygo/c1/108
Hello, Could you please send me the latest firmware file for 86140-YV010 ? My version is currently at Audio 8.10, OS1 8.10, OS2 8.14.
Thanks!
Hello,
First thanks for all informations in this topic, I just bought a 86140YV010 and all is working and I get Apple Carplay now! 🙂
But the micro isn't working because I don't have it in the interior light (I have a Citroen C1 with the basic radio without touch screen).
I saw others topics talking about how to connect the microphone on the 28 pin connector (like this one:
I bought a original microphone on eBay (like the image above) but now I don't know technically how to do it...
Someone can help me?
Thanks!
Thanks @flash22 for your response.
But do you have more informations about connectors to use please (and maybe the type of wires) ?
There is no post about that...
Did you just get the microphone without the plug ?
wire size is not that critical, 0.35mm2 (12/0.20) thinwall will be fine
I got the same thing in this image (micro, connectors and wire cutted off): 1647729798_WhatsAppImage2019-07-03at12_5
Ok thanks for wire size, but now where can I find the wire connector for the 28 pins connector? And did you know if I can reuse the mic connector?
Strip the wire back, join the new wires to it, either solder and heat shrink or crimp it
At the radio end just add the terminals or pigtails (pre crimped terminals with a length of wire)  and insert into the existing plug
Hey guys, I just found this thread after being disappointed with a chinese HU and now knowing what to do
I have a Toyota Aygo with a rear camera from 2014 with the following Headunit
Modell-ID:13TPDAEU-EA01
SAM ID:AEAICDJQDH
Hardware-Nr.:86140-0H010
Which of course cant do anything, no Android Auto,no Car Play, no "x-play" or anything.
I have read the first 4 pages and figured it was easier to just ask:
could I just order a 86140-YV020 unit and it would "just work" ?
i am located in Germany if that helps, because I saw you mentioning specific UK models?
SAM ID:AEAICDJQDH
Yes it would just be a direct swap plug and play.....
